Drew5920
Message 1 of 3
Complement BtopenReach Engineer
I have got to i have had a lovely engineer who delt with the problem today he managed to fix one problem and he worked so hard if openreach had more like this engineer it would have a great staff. I will say this engineer and the last took there time AND got the problem sorted Thank you to them both today engineer was Wojciech and if there is a star award he should get it
2 REPLIES 2
Moderator
Moderator
Message 2 of 3
Re: Complement BtopenReach Engineer
@Drew5920 thanks great I'm glad the engineer got you sorted. Openreach do have a thank you form where you can leave feedback which will go to his manager.
Community ModeratorNeilO
Show your appreciation!
Kudos”Kudos”
Drew5920
Message 3 of 3
I Have left feed back as i do hope that he dose get some recognition for all his hard work
And a big Thank you 🙂
