Message 1 of 12
Ducting 54mm
We are building three houses on our site, using 54mm ducting can all three houses join into one underground ducting ?
11 REPLIES 11
Message 2 of 12
Re: Ducting 54mm
This is a BT retail site. You would need to ask Openreach, it has nothing to do with BT.
Message 3 of 12
Re: Ducting 54mm
Hi @Julie29 I'd recommend checking out the Openreach developer's website
Neil
Message 4 of 12
Re: Ducting 54mm
Message 5 of 12
Re: Ducting 54mm
Thanks you
Message 6 of 12
Re: Ducting 54mm
Thanks, tried that and sadly it doesn't say
Message 7 of 12
Re: Ducting 54mm
Thanks, tried that and sadly it doesn't give the information
Message 8 of 12
Re: Ducting 54mm
I suspect you are going to have to pay for a survey first. Either way, you must register your site, if you want Openreach to provide a connection to the network.
Message 9 of 12
Re: Ducting 54mm
We have registered the site but trying to get any information is painful
Message 10 of 12
Re: Ducting 54mm
You would need to use the same type of duct Openreach use and build it to their specifications otherwise they won’t let you connect it to their Network, nor would they adopt it once installed and the homeowners would then ultimately be, which may cause problems for them in the future.
