Ironside
Message 1 of 3
Ethernet external hard drive
Can somebody recommend an ethernet external hard drive that works well with the BT Smart Hub.
2 REPLIES 2
TimCurtis
Guru
Message 2 of 3
Re: Ethernet external hard drive
@Ironside
I use a WD My Cloud , it's a NAS as opposed to a straight HDD but works well. Mine's a couple of years old now but the current ones start around £120 for 2TB
Bob1001
Expert
Message 3 of 3
Any NAS drive should work, however there are no stand alone hard discs that will connect by Ethernet.
