DominicButler
Message 1 of 8
Ex Employment reference
Hello,
I used to work for BT Openreach and trying to find the contact details to get a reference for a job.
Thank you
Dominic
7 REPLIES 7
Message 2 of 8
Re: Ex Employment reference
UnitW
Newbie
Message 3 of 8
I used to work for BT Openreach and trying to find the contact details to get a reference for a job, what is the contact number for callers from abroad other than 08001814321 ?
Moderator
Moderator
Message 4 of 8
Hi @UnitW and welcome.
Thanks for posting. I've sent you a message with the contact details so you can get your reference. Let me know how you get on.
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”Kudos”
DominicButler
Message 5 of 8
Can you please inbox me the details for this as well?
Thank you
Dominic
Message 6 of 8
DominicButler
Message 7 of 8
Is there not an e-mail address as I'm not in the UK so it will be difficult to ring HR
Moderator
Moderator
Message 8 of 8
Hi @DominicButler  and welcome.
Thanks for posting. I've sent you a private message with the details you need.
Cheers
David
Kudos”Kudos”
