DominicButler
Message 1 of 8
Ex Employment reference
Hello,
I used to work for BT Openreach and trying to find the contact details to get a reference for a job.
Thank you
Dominic
7 REPLIES 7
Message 2 of 8
Re: Ex Employment reference
UnitW
Newbie
Message 3 of 8
I used to work for BT Openreach and trying to find the contact details to get a reference for a job, what is the contact number for callers from abroad other than 08001814321 ?
Moderator
Moderator
Message 4 of 8
Hi @UnitW and welcome.
Thanks for posting. I've sent you a message with the contact details so you can get your reference. Let me know how you get on.
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
DominicButler
Message 5 of 8
Can you please inbox me the details for this as well?
Thank you
Dominic
Message 6 of 8
DominicButler
Message 7 of 8
Is there not an e-mail address as I'm not in the UK so it will be difficult to ring HR
Moderator
Moderator
Message 8 of 8
Hi @DominicButler  and welcome.
Thanks for posting. I've sent you a private message with the details you need.
Cheers
David
Kudos”
