Ezenia
Message 11 of 17
Re: Extension phone socket not working
The guy was right. I connected the green and brown wires to the terminals (2 and 5) on the front plate and the extension socket now has a dial tone.
Clairec
Message 12 of 17
Hi does it matter whether you connect the brown or green to number 2 and 5 and is it difficult to get them connected to the numbers
Devon_Dave
Distinguished Guru
Message 13 of 17
Who is your line provider?
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
RobbieBaron
Message 14 of 17
@Clairec: It does not matter which way round you connect them as long as they go to terminals 2 & 5.
Clairec
Message 15 of 17
Can I also ask can there more than one wire in each of the numbers
imjolly
Message 16 of 17
it is quite common in extension socket where the incoming wires and outgoing wires to another extension are connected to same 2&5 terminals. I.e. Extensions connected in series
RobbieBaron
Message 17 of 17
@Clairec: If you are asking about the master socket there could be more than 1 pair of wires connected to terminals 2 & 5; 1 pair for each live extension in the home. I.e. Extensions connected in parallel.
