Message 1 of 20
FTTP Church Gresley
Does anyone know the programme for Church  Gresley FTTP programme - I have received an email confirming it is coming to our area - currently fed from Box 50 - thanks
19 REPLIES 19
Message 2 of 20
Re: FTTP Church Gresley
just keep checking here https://www.broadbandchecker.btwholesale.com/#/ADSL
Message 3 of 20
thanks for this but the site says its available but can not order !!!
Message 4 of 20
It shows that FTTP on Demand is available not FTTP.
They are two different products. FTTP on Demand is when you pay to have a bespoke fibre system installed at your property and you cover all the costs of the installation which can run into thousands of pounds. Due to the cost this is mainly aimed at businesses.
Message 5 of 20
As you already have an FTTC connection, then its not likely Openreach will be installing FTTP anytime soon.
Message 6 of 20
thanks hadn't notice that but as said BT have confirmed its coming soon but ideally want to understand the programme of role out etc.
Message 7 of 20
only openreach know when 'coming soon' is  but from others could be months or even years  just need to keep checking dslchecker
Message 8 of 20
thanks will keep an eye on the web site
Message 9 of 20
Can anyone at BT comment on the install programme as I see VM are gearing up to install in the area as well
Message 10 of 20
As I posted already only openreach would know when or if they are going to lay FTTP in your area.  This has nothing to do with BT RETAIL
