jacks
Message 1 of 2
How are BT Forums/Community organised ?
How do I view sub boards ?
Not impressed with layout.
1 REPLY 1
Message 2 of 2
Re: How are BT Forums/Community organised ?
Assuming you are using the full view on a PC or laptop, there is a menu line at the top of the page. It starts with Community > Announcements etc etc. Hover over each one and you will see the sub boards.
If it is on a portable device try clicking on the three lines at the top left and you will get a drop down menu for the main headings then the sub boards.
 It might be worth reading these links
https://community.bt.com/t5/Announcements-Guides-Community/Welcome-to-the-BT-Community-Forum/td-p/15...
https://community.bt.com/t5/Announcements-Guides-Community/BTCare-Community-Forums-User-Guidelines/t...
https://community.bt.com/t5/Announcements-Guides-Community/BTCare-Community-Forums-Terms-of-Use/td-p...
