Anonymous
Not applicable
Message 1 of 3
How do I cancel being a community member?
I have unsubscribed , I have changed all settings that say never get any updates yet I am getting constant replies to a post I made.  I cannot see anywhere that tells me how to delete ‘membership’.
Surely, the unsubscribe button should sort this in accordance with GDPR etc.. does it take time to implement?
thanks
2 REPLIES 2
Community Manager
Community Manager
Message 2 of 3
Re: How do I cancel being a community member?
Hi @Anonymous,
Thanks for the comments and welcome back to the Community.  I am very sorry that you have been unable to unsubscribe from notifications.  There must be a problem as if you change the setting on your profile to unsubscribe this should be honoured.
I am going to look into this for you now and figure out what is going on.  If the notifications don't cease then I will raise a support ticket to our supplier to fix this.
Is it a case that you would like to remove your Community profile because you are still receiving notifications, or is removing your profile still something you want to proceed with?  I can help with either but if your reasoning is because of the notification problem then I would like to fix that for you so you don't have to leave us.
Cheers
Sean
Community ManagerSeanD
Show your appreciation!
Kudos”Kudos”
Community Manager
Community Manager
Message 3 of 3
Hi @Anonymous,
Me again.  I have checked and doubled checked your setting as all subscription notifications have been turned off.  Please let me know if you receive any further emails.  If this does happen again I will raise a support ticket to our supplier for further investigation.
Cheers
Sean
Kudos”Kudos”
