zebedee1
Newbie
Message 1 of 3
Hub and 4G or stick with BT?
Hi, I'm out of contract and wondering why I am paying for a landline that I never use for calls. My mobile is unlimited. I have teenagers/netflix so the speed and reliability are essential, which I've always had from BT to be fair.   I'm tempted to get a u/l 4G 3 Hub instead (as I'm in a good 4G area) as it's so much cheaper each month without a landline. But I'm not sure what the drawbacks are? Can anyone help me, as it seems too good to be true? many thanks, Lily
2 REPLIES 2
albertj
Message 2 of 3
Re: Hub and 4G or stick with BT?
Hi @zebedee1 ,
Unfortunately, discussion of other suppliers is not allowed on here.
You can post your question at a form like ISPreview for an unbiased opinion.
But I recommend you do a search for #HomeFi on Twitter, I think you will draw your own conclusions about HomeFi.
You can get a free sim card with 200mb data from three to test the speeds.
If I have helped you in anyway please press the Kudo button (thumbs up)
If I have resolved your query please click 'Mark as Accepted Solution'
Message 3 of 3
@zebedee1
Unfortunately you are not allowed to discuss other providers on this forum.
Try posting on https://forums.thinkbroadband.com/
Specifically https://forums.thinkbroadband.com/mobilebroadband.html
This is an independent forum so you should get some balanced comments.
