PaulAndVikkie
Message 1 of 5
Internet working fine but landline not
I have just realised our phone line is down and yet our Internet is working. We only have one phone in the house and this plugs directly into the nte5 master socket. The black bt cable comes in through the wall at the edge of the bay window and goes into a bt80a junction box and then the internal white cable feeds the master socket from it. I have removed the face plate from the nte5 socket and plugged the phone in both directly and with a micro filter into the test socket and still no dial tone and cannot call out or receive calls. I have repeated this with a borrowed phone in case ours is bust but get the same result. I am a qualified electrician and have tested the A B incoming lines and there is only .03 v reading and I have retested at the rear of the master and get the same result .03v Dc. To me this indicates there is a problem on the line prior to my property as my understanding is it should be a 50v dc feed across AB wires . The wiring continuity inside checks out with .03 readings across AB on the first internal junction box and the same reading at the back of the master.  Would the cause the phone line not to work but still enable the Internet to work or am I missing something?
4 REPLIES 4
Keith_Beddoe
Message 2 of 5
Re: Internet working fine but landline not
@PaulAndVikkie
Welcome to this user forum.
Who provides your phone  service?
Is your Internet working at full speed?
PaulAndVikkie
Message 3 of 5
Sky provide service internet fine working at avg 40 mb/s which I know is not fantastic but is fine for our useage
Keith_Beddoe
Message 4 of 5
Then you will need to contact Sky, as this forum is for BT Retail customers only. Its Openreach not BT Retail that provide the external network, but I would suspect an issue with the Sky exchange equipment, as they have their own exchange equipment.
Sky do have a user forum which you should register on.
Sky User - The unofficial support forum for everything Sky!
PaulAndVikkie
Message 5 of 5
Many thanks
