Newbie
Message 1 of 3
Junction Box
I moved into my house last year and had Virgin installed.  BT have asked if they can run cables from the junction box on the back of my house.  I wasn't home so they left a message with someone else.  They mentioned it's to connect to fibre?  My house is beside a path so I think it's easy access for them.  Does anyone know why I have to be involved at all when I'm not a BT customer?
2 REPLIES 2
Message 2 of 3
Re: Junction Box
@sandym1611
It would have been Openreach not BT Retail.
If the junction box is on your property, then you would have to enter into a wayleave agreement with Openreach for them to run optical fibre.
https://www.openreach.com/help-and-support/obtaining-wayleaves
This optical fibre would be used to supply other customers, and possibly yourself if you decide to change your provider from Virgin Media.
Newbie
Message 3 of 3
Re: Junction Box
Thanks Keith
