margih
Message 1 of 20
LG wireless sound bar for my tv model SK4D.
I have a wireless LG soundbar model SK4D. When I turne the volume up on my tv it display TV speaker the sound is up to 50 but not very loud is this right? When I use the silver smart remote the sound is like a home cinema for some reason. I have also seen the button marked ASC what does that do and when should I use it ?
19 REPLIES 19
Zurdo
Message 2 of 20
Re: LG wireless sound bar for my tv model SK4D.
Online manual tells you all about it, here.
https://www.lg.com/uk/support/support-product/lg-SK4D
Andy005
Message 3 of 20
Hi @margih, it sounds to me like your sound bar isn't connected to your TV. Have you connected the sound bar to the TV with a digital optical cable?
margih
Message 4 of 20
My husband said that he had done this how do we check that it has been done correctly?
Andy005
Message 5 of 20
The connections should be marked 'Optical' and the plug is round with a flat on one side, it's slightly smaller than a pencil. If the cable is plugged into the TV and the TV is on, you should see a red light coming out of the other end of the cable.
margih
Message 6 of 20
It looks as thought that has been done . But when I go to settings it says that the sound output is tv speakers Is this the problem ?
Message 7 of 20
yes   should say external speakers
margih
Message 8 of 20
So how do I change this please?
margih
Message 9 of 20
I have now managed to change it to say SK4D (E) is this now correct . It sounds better.
margih
Message 10 of 20
LG Sounder connection
I connected my LG soundbar to my Samsung TV. I think I have done it correctly when I go to sound output it shows SK4D(E). However overnight when the TV is off it reverted to TV speaker any ideas why this happens and how do I put this right?
