simon132
Newbie
Message 1 of 10
MK3 socket wiring
Hi, I would like to move my BT MK3 socket off the main wall into a small cabinet.  This means I would have to disconnect the wiring, pull it back into the cabinet (through the small hole shown below) and then rewire.
My query was  - how do I disconnect  the orange and blue wiring shown below?  I couldn't see an obvious way to do this.  Is there a particular knack with a screwdriver (I don't have a punchdown tool) ?  Thanks!
9 REPLIES 9
Message 2 of 10
Re: MK3 socket wiring
the cables just pull out but better with the IDC tool rather than screwdriver when you replace them
Message 3 of 10
If you must use a screwdriver, use a very thin bladed one or all you will do is splay the contacts so the wires don't make proper contact.
Message 4 of 10
@simon132
Who provides your phone and broadband service?
The external wiring is owned by Openreach, and you could incur a charge if alterations cause problems on the network.
simon132
Newbie
Message 5 of 10
thanks for the replies.
I am with Sky for broadband and phone
Message 6 of 10
then you should be posting on SKY forum not BT retail
Message 7 of 10
Then why are you posting on a BT retail customer forum?
It would be best to ignore any advice given here, as its likely to result in Sky raising a charge if you do it wrong. BT would not be responsible if that happens.
Try the Sky forum http://www.skyuser.co.uk/forum/
simon132
Newbie
Message 8 of 10
Because it is a BT MK3 socket.
I will delete the post though, thanks for the responses.
Message 9 of 10
the socket is openreach not BT retail.  SKY have as much contact with openreach as do BT Retail of any other ISP
you cannot delete the thread now
simon132
Newbie
Message 10 of 10
thanks
this seemed the best place to find information, hence my request.  I guess it was from more of a DIY point of view.  I'm quite happy doing general DIY but just wanted to see if there was an easy trick to getting the small incoming wires off and back on again.
