Message 1 of 7
Multiple line aggregation for domestic premises
6 REPLIES 6
Message 2 of 7
Re: Multiple line aggregation for domestic premises
Why can't BT/Openreach provide rural users with aggregated line services(more than 1 line and/or medium) to increase the total available capacity to a single property?
Message 3 of 7
They can if you are prepared to pay for two or more lines!
Message 4 of 7
If you are a business customer there is the hatteras box which will combine a number of broadband lines to give an increase of speed
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Message 5 of 7
Thanks for the info.
Is there a special procedure by which the compound service is supplied?
Message 6 of 7
You would need to contact BT business to see what options are available.
Message 7 of 7
Hi,
I thought that it might be available via this
Broadband for Working from Home | Second Line | BT
However that invites customers to install  a second discrete line...
Thanks very much....
