RBO27
Message 1 of 3
Neighbours telephone wires need moving so that an extension can be built - help needed
Hi,
So I am having an extension built, however, there are 2 wires which cross my land going from a telegraph pole to 2 different neighbours homes which crosses the land which will be built on. The build cannot go ahead until this is sorted.
There is another telegraph pole at the other side of these houses (a similar distance to the first) which i am hoping they could connect to instead.
Is it possible for the engineer to simply disconnect from one pole and re-wire to another?
Also, Is it my responsibility to have to pay for this or can some ownership be taken by the neighbours?
Has anyone had any experience with something similar or have any advice?
I’m very aware I may be charged an extortionate amount of money to sort this 😣
thanks
2 REPLIES 2
imjolly
Message 2 of 3
Re: Neighbours telephone wires need moving so that an extension can be built - help needed
you need to contact openreach.  the cost will be charged to you
https://www.openreach.co.uk/orpg/home/submitFeedbackLoggedInUser.do
NeilO
Moderator
Moderator
Message 3 of 3
Hi @RBO27 thanks for posting, if you fill in this Openreach webform they will complete a survey to see what work is needed and let you know the costs involved.
Neil
