Message 1 of 5
Not able to access specific website
Hi,
I am having a real struggle to understand the issue and I have a problem accessing the following website
search for 'exampapersplus.co.uk'
I have tried all the suggestions related to ssl error over the web nothing worked. I am able to access it from my 4g connection.
Can you guys try from your BT broadband and let me know if you guys have the same issue?. I am able to access it from my workplace. I Have tried from laptop, desktop and iPad with different versions of browsers with no luck.
Regards
4 REPLIES 4
Message 2 of 5
Re: Not able to access specific website
No problem here, make sure you have turned off web protect. https://www.bt.com/help/security/set-up-and-use-bt-web-protect
Message 3 of 5
Possibly classed as academic fraud, and blocked.
Message 4 of 5
Not blocked for me
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Message 5 of 5
@Devon_Dave
The website is being heavily promoted elsewhere, so I would suspect they are trying to raise their search engine ranking.  Its accessible on BT broadband.
