Message 1 of 8
Replacing BT8600 phone handset batteries
Hi . I have a BT8600 DigitalCordless Phone , I,ve had it quite a few years  and want to change the batteries ,
the instruction booklet says it 2 x AAA Ni-MH 750  mAh   rechargeable batteries ,  but the nearest I can get is the
800 mAh ,      Tried a couple places but nobody seems  to have the 750, so will the 800mAh be safe enough   ?
7 REPLIES 7
Message 2 of 8
Re: Replacing BT8600 phone handset batteries
@Keith19
Welcome to this user forum for BT Retail phone and broadband customers.
Yes, 800mAh will be just fine.
Message 3 of 8
Hi , thanks for the quick reply , will try it  later
Message 4 of 8
Hi , managed it , seems to be working OK . Got a bit arthritis in my hands so bit fiddly getting the back off , once again thanks ..  Keith
Message 5 of 8
Hi @Keith19
I replaced my batteries recently.
"Pack of 4 BuyaBattery BT AAA Rechargeable Cordless Phone Batteries 750mAh 1.2V NiMH"
Message 6 of 8
@VeteranISPUser
Please remove the Amazon e-commerce link, as its not permitted on this forum. Thanks.
Message 7 of 8
Thanks for the tip that the back can be removed. I was afraid that it was a sealed unit. I have now got the back off and replaced the batteries with a couple of 750 mAh rechargeable batteries that my local hardware store sold me. (They were Duracell so a bit pricy, but the old ones lasted for years.)
Message 8 of 8
I found a bit on youtube showing you how to do it
