Message 1 of 7
Replacing phone socket - A & B
Hi
i have bought a replacement to replace the BTpbone socket however it does not have an A and B like the old unit so wondering where the wires would go for it to work?
Tags (2)
6 REPLIES 6
Message 2 of 7
Re: Replacing phone socket - A & B
are you a Bt Broadband and phone customer
which master have you got
Message 3 of 7
Mine appears to be number 2
Message 4 of 7
@Rob_2020
Are you a BT Retail  phone customer?
Its not a BT socket any more, it belongs to Openreach, and you should not be interfering with it.
Message 5 of 7
Understand the general consensus.
However was looking more so for an constructive answer to my query rather than any BT / Openreach police.
Message 6 of 7
This is a BT Retail Customer forum. If you get your phone service from another provider, then you need to ask on their user forum.
You have an NTE5C, if you do a Google search you should be able to find how to connect things up.
Bear in mind if you damage either your provider`s exchange/broadband equipment, or the external Openreach cabling, then you are likely to incur a charge.
The official Openreach guide is here https://www.openreach.co.uk/orpg/home/helpandsupport/how-toguides/howtoguides/downloads/NTE5C_Instru...
It would not cover the external wiring connections, as they are not intended to be accessed by the end user.
If you are not sure what to do, then find a local telephone technician who can help.
Message 7 of 7
Ok thank you I will take a look.
