Message 1 of 3
Samsung S9 Battery drawing rapidly
I've had my phone for around 18 months and since the latest android update on 24th May my battery is draining rapidly e.g 100% to 1% in 3 hours with not a lot of use.  I've contacted Samsung Community  who looked at my battery usage and   BT Virus Protect seems to be causing the problem.  They've suggested disabling but don't  really want to do this.  Has anyone else got this issue? Or can anyone help?  TIA
2 REPLIES 2
Message 2 of 3
Re: Samsung S9 Battery drawing rapidly
If you are sure that problem is BT protect then I wouldn't think twice about turning it off. If you are concerned then install a visual check app
Message 3 of 3
Thanks and sorry for asking but what do you mean by a visual check app?
