Message 1 of 3
Soundbar
I have just taken delivery of the new BT TV Pro box.   Can anyone recommend a Soundbar to add to the system.  I have an old Orbitsound sound bar but the connection isn't compatible.   Thanks.
2 REPLIES 2
Anonymous
Not applicable
Message 2 of 3
Re: Soundbar
How much is your budget @Eddie5 and what make/model TV do you have so we know if you have ARC, eARC or optical audio options?
I’m a big fan of the Sonos Beam (Gen 2) personally, but there are lots of options out there.
Message 3 of 3
Re: Soundbar
Problem solved by plugging into the the back of the TV instead.  Thanks for your response.
