DiggerOfTrenches
Message 11 of 14
Re: Universal Service Obligation
@Starwirewrote:
Not sure what Fibre Network you’re referring to but the one I work on uses a 32 way split. So that’s 1 Fibre into a SASA then 32 out. Openreach try to use only 28 Fibres per SASA and leave 4 spare but in reality that hardly ever happens and all 32 get used.
Even if there was a spare available on the SASA they wouldn’t be able to use it to supply service to a DSLAM anyway.
Why 'Even if there was a spare available on the SASA they wouldn’t be able to use it to supply service to a DSLAM anyway.'?
so n = 0.25 why ask what n is if you allready know?
DiggerOfTrenches
Message 12 of 14
Are you a BT customer?
Distinguished Guru
Distinguished Guru
Message 13 of 14
No he's not and doesn't need to be. Forum rules won't allow me to tell you what he is, suffice to say he knows more about the Openreach fibre network than you or I.
DiggerOfTrenches
Message 14 of 14
M
Lots of the word CUSTOMER in these rules?
Could you quote the Rules not just state them please?
