AllenC1
Message 1 of 3
Video Interview
Hi, I completed a video interview with BT back in early June and was wondering if anyone could shed some light on when the next assessment centre day will be? Thanks
Tags (1)
2 REPLIES 2
Moderator
Moderator
Message 2 of 3
Re: Video Interview
Hi @AllenC1, Thanks for posting, this isn't really something that the BT community forum will be able to assist you with as it's intended for use by BT consumer customers.  I take it that you've applied for an engineering role within Openreach? If so you'll need to make enquires directly with Openreach to find out when the assessment centre day will be.
Community ModeratorNeilO
Show your appreciation!
Kudos”Kudos”
Message 3 of 3
Re: Video Interview
@AllenC1
Try http://forums.thinkbroadband.com/job.html
There is a lot more information and plenty of postings, so you may be able to get some idea of the timing.
