Message 1 of 7
What do the numbers on the BT ground cover right outside my house mean?
Anyone have any idea what these mean?
6 REPLIES 6
Message 2 of 7
Re: What do the numbers on the BT ground cover right outside my house mean?
Bump.
Message 3 of 7
It’s nothing really to do with BT , given that it’s Openreach that are responsible for the external network infrastructure, but I suspect it’s not Openreach markings either ,  I think those markings were made by an Alt Net using PIA ( physical infrastructure access ) and probably indicate a blocked duct , and the measurements from the box to where they suspect the blockage or blockages to be.
Message 4 of 7
I believe the engineer who setup my internet a month back put that there.
Is it possible it means the distance to the cabinet?
Message 5 of 7
No, anyway OR use grey paint when marking up, what possible benefit would there be ,marking on the pavement the distance to the cab from a random jointbox, plus OR employees wouldn’t use ‘BT’ , because it’s nothing to do with BT , civils contractors or Alt Net employees on the other hand tend to incorrectly refer to OR as BT .
Message 6 of 7
Oh alright, by the way, is there any way to find out your distance to the cabinet?
Message 7 of 7
TBH nobody here will know & to be blunt it's really none of your busines seither
