Message 1 of 2
WiFi 2.4 works well only when desktop is off or asleep
After powering on the computer I have ~10minutes before the 2.4ghz drops dead. Tried narrowing down the source of the problem but the Sonos soundbar seems happy and so does the micro. Replacing drivers and rebooting the Partner fibre router sometimes doesn't help at all.  The hot water tank is connected and without 2.4 I cannot set the ontime and I usually forget I have turned it on. One neighbour has a very strong signal but it all seems so random.
1 REPLY 1
Message 2 of 2
Re: WiFi 2.4 works well only when desktop is off or asleep
@MIKELA
Are you a BT Broadband customer?
Partner Fibre is nothing to do with BT Retail.
