Fulbourn
Message 1 of 2
YouTube - 3 channels
I had one YouTube channel for my songs. Don’t know how but they are now distributed over three channels. I do not know the names of two of the channels! What I would like is for all my .mp4 songs to appear on my original channel (fulbourn27). Is there a control panel where I can delete files from the two unwanted channels and then move them to my original channel (fulbourn 27 - terrybraverman).
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: YouTube - 3 channels
@Fulbourn you might be best asking this on the youtube forum
Community ModeratorNeilO
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
