wytey
Message 1 of 3
iphone 5 data usage
settings, usage, cellular usage, cullular network data
probably ios 6.1.2
but when the iphone is on standby for a while. and you wake it up, it is on 3g and then switches to wifi, this never happened with the iphone 3gs or iphone 4, or at least didn't, anyone with iphone running ios 6.1.2 want to verify?
the problem is that everytime it does that a little bit of data is sent, not an issue for those on unlimited data, bundled data etc, but for those without or pure payg, that will eat into the data usage/credit
you could switch of cellular data, but that would mean switching it on everytime you needed to use it
2 REPLIES 2
Distinguished Guru
Message 2 of 3
Re: iphone 5 data usage
Yup happens to me ....
BTLife | 1967 Plus Radio | 1000 Classical Hits
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Helpful Post?
If a post has been helpful, say thanks by clicking the ratings star.
Guru
Message 3 of 3
Mine stays connected when locked to the WiFi.
If this helped you please click the Star beside my name.
If this answered your question please click "Mark as Accepted Solution" below.
