Newbie
Message 1 of 5
reset fix phone
I have some Motorola l404 phones that have gone into out of range or in searching mode.  the phones wont work anyone can help me out?
thanks
bob
4 REPLIES 4
Message 2 of 5
Re: reset fix phone
@cwop
As these phones are not sold by BT, its unlikely this BT customer forum would be able to help.
Distinguished Guru
Distinguished Guru
Message 3 of 5
Re: reset fix phone
See if you can get help here.
Newbie
Message 4 of 5
Re: reset fix phone
no tried that they don't mention how to fix.  I think I need to do a completer reset and they don't discuss that.
thanks
bob
Message 5 of 5
Re: reset fix phone
FWIW years ago I was given a pile of cordless phones that had become "un paired", sometimes you have to be a bit creative looking for a manual online as many of the phones are widely rebadged. In my somewhat strange case I found the equivalent phones by cross referring the replacement batteries and then doing a Google image search until I found a phone that looked identical. My ones all paired correctly once I found the sequence of how to do it.
