Message 11 of 20
Re: Email folders not visible/ accessible on Android phone
I'll continue to feed this one back for you @Martinwales.
Have you tried the BT Mail app on your phone to see if this is without issue as well, and does your wife's phone experience the same issue when logging in via a browser?
Peter
Message 12 of 20
Hi I have now tried accessing my BT email account via BT.com on my wife's Redmi Note 10 mobile.
That phone has exactly the same issue as mine. It is unable to access or display the folders.
Message 13 of 20
@Martinwales
Have you cleared the history and cookies of the web browser that you are using and having done that re-started your devices?
If that still does not work try turning your BT hub off for about half an hour. Once it is re started it should have been issued with a new IP address and hopefully connected to a different email server.
Message 14 of 20
Thanks for the suggestion. I tried that, but it has made no difference. The folders are still inaccessible when I access mail via BT.com on both Chrome and Opera on my phone.
Message 15 of 20
Hi @Martinwales
Have you had a chance to try the BT Email app to see if you can access the emails through that?
Chris
Message 16 of 20
@Christopher_G
I have the issue on my Android phone so it has nothing to do with the OP's phone, browser or email account.
This problem would appear to be a programming issue with the BTMail browser's "mobile" version of browsers when viewed on a phone's small screen. There is no problem when viewed using the "Desktop" version on the phone.
I found that it works as it should when viewed on an Android tablet with a 9 inch screen hence my previous post that it was OK on Edge. I have not been able to test on any Apple phones or iPads so I can not say if it is only relevant to Android.
The BTMail email team need to have another look at the problem although given their response the last time stating that it was a storage issue I don't hold out much hope of them resolving it. However there is always a first time!
Message 17 of 20
Thanks, @gg30340
I've messaged the Email team asking them to take another look. Will post an update here when we hear back.
Chris
Message 18 of 20
Delighted to report that I can now view and access all my email folders on my mobile - for the first time in months.
Message 19 of 20
I have checked and it would appear to be working correctly so the email team would appear to have fixed it.
Message 20 of 20
@Martinwales  @gg30340
Glad to hear you're both able to access your folders correctly now.
Thanks for getting back to us to confirm.
Ali
