Message 1 of 2
Ongoing calendar issues
Hi
When I accept a meeting invite it shows 1hr earlier in my calendar than the time of the meeting.  This has nothing to do with time zone (which is all set up correctly).   If I go back into the invite and accept it a 2nd time it moves the meeting forward 2hrs ahead of the correct time.
How do I resolve please??
Cheers
Duncan
1 REPLY 1
Message 2 of 2
Re: Ongoing calendar issues
Hi @redmayne1978
Are you able to change the settings to "Use My Device Time Zone." rather than GMT, if you haven't already done so?
Also, it may be worth checking your router hub also has the correct timezone set. You can do this by going to Login to the hub manager 192.168.1.254 and then navigate to advanced settings.
The username and password can be found on the white label on your router.
Ali
