Message 1 of 8
Repeated prompts for verification codes
Good Afternoon,
Every time I access my emails on webmail, I am getting prompted for a six digit verification Code.
Surely my device  / Location is registered to my account and should not be constantly flagged as suspicious?.
Please advise if this is normal behaviour.
Kind Regards
Geoffrey
7 REPLIES 7
Message 2 of 8
Re: Repeated prompts for verification codes
If you had searched through the forum you would have see that there are numerous posts regarding this.
BT have made Two Factor Verification compulsory when using BTMail and MyBT. This requires the user to verify using a  PIN code sent by BT.  This can not be turned off.
Your device will eventually become a "trusted" device by BT at some point after an unspecified time.
Message 3 of 8
This appears to be a "feature" of BT logins at present. They have recently introduced 2-factor authentication and don't seem to have done it very well. Apparently they are "working on resolving issues with it".
My last attempt at logging in had me putting in codes sent to both my email and to my mobile phone, but I kept getting returned to the login page. After around three to four goes of this nonsense I finally could access my account.
You just have to be VERY patient at the moment!
Message 4 of 8
In which case their customer base surely can and will be!
And what if people want to access email on other devices without mobile, mobile signal or whatever? For BTMail this feature HAS to be user selectable. It's a USER choice, not BT's choice.
Regardless, BT can't be trusted. As this clandestine introduction has demonstated.
Message 5 of 8
@DISRUPTED
As you are no doubt aware this is a BT residential customer to customer forum. Your post does not go to BT.
Lodge a complaint and take it up with BT.
Message 6 of 8
The easy way is to ask google ai, rather than sifting through forums. I emptied the cache on the BT Mail app and ticked the box 'to receive special deals and news'  in My BT. There are also several other options other than using the BT Mail app.
I think it was the cashe emptying that stopped the recent multiple prompts etc. This was just yesterday btw.
Note: I was with BT with everything but have moved over to EE for the mobile.
Message 7 of 8
I have. They do nothing.
Message 8 of 8
I don't think that has anything to do with it (why should it?) I do not use an app, I access webmail using a browser. That I need to do, there is no other option (other than not access at all).
