Do you mean
Newbie
Accepted Solution
BT Sport error message (BTP-20000) and BT Player (BTP-115c)
[ Edited ]
Hi @Martin--W
I'm also having exactly the same issue, is there any chance I could ask for the same assistance please?
Moderator
Re: BT Sport error message (BTP-20000) and BT Player (BTP-115c)
Hi @smithh30 Welcome to the forum and thanks for posting. Sorry to hear you are having a problem with your BTTV service. I've moved your post to create your own thread as that's the best thing to do.
Are you experiencing both the error codes with the BT Sport and BT Player?
Did the service work OK previously or have you been getting these errors since your BTTV service activated?
Cheers
John
Community ModeratorJohnC
Show your appreciation!
Kudos”
Make sure you are logged into the forum otherwise you will not see our contact link when a moderator offers help. When sending us your details please don’t send a Private message (PM), we can’t deal with account/service issues via PM so please use the contact link. Thank You
Newbie
Thanks @JohnC2
Yes. Seems to be exactly the same issue. My service got activated in a new address on the 3rd.
Call centre said they'd fixed it last night, then again today, but still no sports channels or by player.
Moderator
Hi @smithh30 Thanks for the prompt reply.
We will be happy to help you with this if you send us your details. You can contact us by clicking on my user name and selecting contact the mods.
John
Kudos”
Moderator
Hi @smithh30,
Thanks for sending over the details. I tried calling, sorry I missed you. Can you please check if this has been sorted? If you're still having problems can you factory reset the hub and let me know if that helps.
Cheers
David
Community ModeratorDavidM
Kudos”
Newbie
Hi David,
Sorry for my lack of reply, all sorted now. Thanks very much for your help!
