Do you mean
Guru
0
Accepted Solution
Channel 317 wrong aspect ratio this evening
Looks like.National Geographic SD 317 channel is currently being transmitted in the wrong aspect ratio.
The National Geographic HD 373 channel is being transmitted in the correct aspect ratio.
First reported on Youview community
https://community.youview.com/youview/topics/update-27-50-0-ratio-default-to-4-3?topic-reply-list%5B...
Moderator
Re: Channel 317 wrong aspect ratio this evening
Hi @zulu17
Thanks for highlighting this.
I've let the guys know about this and it's being looked into.
Thanks again!
Robbie
Community ModeratorRobbieMac
Show your appreciation!
Kudos”
Make sure you are logged into the forum otherwise you will not see our contact link when a moderator offers help. When sending us your details please don’t send a Private message (PM), we can’t deal with account/service issues via PM so please use the contact link. Thank You
Guru
0
Someone not checking the output screens?
Stew
Guru
0
Looks like it is back to correct aspect now.
Moderator
Hi @zulu17
Yes, the issue was sorted shortly before 8pm last night.
Thanks again for taking the time to highlight this Smiley Happy
Cheers,
Robbie
Kudos”
