Do you mean
Accepted Solution
Error message IPC6007 and BTP-115C
I am getting IPC 6007 for the subscribed channels (BT sport, AMC...) - the message says there is a problem with my broadband however when I check the connection it says it is connected. It used to work some days ago. I am using a broadband extender. When I run account checks on myBT it says there is no BT TV services linked to my account, however I can see it in my package.
I also have an issue with BT player (BTP-115c)
Can I get some assistance please? BT chat have not been able to help at all.
Regards
Christophe
Re: Error message IPC6007 and BTP-115C
I have asked a moderator to provide assistance, they will post an invite on this thread.
They are the only BT employees on this forum, and are based in the UK.
Forumhelp (Private website) Lots of additional information for BT Residential Broadband connections only.
Moderator
Hi @cquina,
I'm sorry you're having problems with your BT TV service. I'll be able to help you with this. Please can you send me in your details using the "Contact The Mods" link found in my profile?
PaddyB
Community ModeratorPaddyB
Show your appreciation!
Kudos”
Make sure you are logged into the forum otherwise you will not see our contact link when a moderator offers help. When sending us your details please don’t send a Private message (PM), we can’t deal with account/service issues via PM so please use the contact link. Thank You
Thanks, I have sent my details now.
I have started having the same error i have the tripple pack of BT extenders. if I press up or down on channel the subscribed channels start but is frustrating as all was working fine before I had the additional screen/option
Moderator
@cquina I've spotted a problem with the the subscription which should be sorted now, can you try the extra channels again and post back to let me know if they're working?
Community ModeratorNeilO
Kudos”
Thanks, it is working now.
Moderator
@cquina That's great, thanks for posting back to let me know.
Kudos”
