Do you mean
Recognised Expert
0
Re: Multicast Settings for 3rd Party Routers may not work
[ Edited ]
quick update - took the router back to shop and got refund - now debating which router to get
@zarf2007 - was it just the simple enabling of the the IGMP Proxy under the lan settings on the Archer C7
0
yes, it was 'igmp proxy' and under LAN settings and it is enabled by default....also make sure that you download and update to the latest available firmware as the earlier one had all kinds of wireless issues which have now been resolved.
theres a review of it on smallnetbuilder as well, the wireless 5G speed/range is unbeaten by any other router at the moment.
Recognised Expert
0
thanks - the prices have dropped so may look into getting one seeing it works and tp-link support has been brilliant in the past (swapping router after 35 months, without any issues) unlike Asus.
local Currys/PC World didn't have any in stock otherwise may have picked one up
Recognised Expert
0
Could I have a definitive statement as to which TP-Link routers work 100% on BT Infinity & support - with a simple setup - IPTV and other Youview features please?
My Asus is going to go I think & my Billion lacks media & ftp server functionality and multiple USB ports.
0
The TP-Link AC1750 works out of the box without any setting changes, the only thing I would recommend is updating the firmware to the latest version before use.
This is for IPTV, Internet and all Ondemand/Youview features.
Recognised Expert
0
So you don't need to do anything like was tried on the Asus of assigning Lan ports to the IPTV input?
The reason I ask is that I use 3 x 4-port homeplugs with 6 units being received at the router lan port, like Sky HD, Blu-ray players etc along with the YouView box.
0
Tim, I'm using the TP-Link TL-WDR4900 N900 with Infinity and YouView. Works flawlessly
Newbie
I've got an Asus RT-AC66U router. I was having the same issue as those with the those with the RT-N66U.
I'd assumed it was due to me using powerline adapters to connect up the YouView box and possibly due to my relatively slow connection speed 14-15Mb due to distance from the exchange.
But when I reverted to my HH3 BT Sport and extra channels worked fine.
I played around with getting the Asus router to work and finally managed to get it working with BT Sport, the extra channel and on demand.
I've using the latest firmware: 3.0.0.4.374.130
I'm using the following settings in LAN > IPTV:
'Select ISP Profile' = None
'Choose IPTV STB Port' = None
'Use DHCP routes' = Microsoft
'Enable multicast routing (IGMP Proxy) = Enable
'Enable efficient multicast forwarding (IGMP Snooping) = Enable
'UDB Proxy (Udpxy) = 0
It still didn't work with these settings. The key to getting it to work for me was to change a setting under WAN. I changed 'Enable VPN + DHCP Connection' to 'No'. I'm pretty sure this is a new setting introduced in a recent firmware update as I don't remember seeing it before. It was set to 'Yes' for me even though I'd never set it.
Hope this helps someone.
0
I don't watch sport, though like to see things working, so tried this and works for me too, that's with Merlins latest "Beta 3" firmware (372.32).
Good discovery, great first post.
0
nope, it looks like the TP-Link just proxys the IGMP multicast traffic to all LAN ports, I have two of them feeding homeplugs which then feed a Humax and ebay bought talktalk youview box and both work fine with IPTV channels/on demand.
