Do you mean
Not turning on
My youview box (which I've had since the pre-release days as part of a trial) has recently started not turning on. I press the remote and nothing happens. I do make sure the remote is in PVR mode. The only way to get it to come on is to reboot it. Anyone else had this problem?
Re: Not turning on
Hi there JohnKelly,
                       I have been having the same problem too. I have been having this problem for the last 5-6 days. Can I ask how long it takes your YouVeiw box takes to come on? As mine can take anything from 5 - 13 minutes, and it is completely blank till I reboot it.
