Do you mean
Re: Persistent IPC6023 errors
[ Edited ]
@valleysboy16
Why are you using the W9970 with an Openreach modem, as its not needed?
The W9970 works fine as a VDSL modem/router, and is very stable.
So does your W9980.
Forumhelp (Private website) Lots of additional information for BT Residential Broadband connections only.
@Keith_Beddoe
Yes, I realise that both will work quite happily as VDSL modem/router - and as I explained I may give it a try after the holidays.
I originally went back to the HG612 mid-2105 when I was having problems with the HH5A, and it has proved to be wonderfully stable.
I also value being able to run DSLstats against the HG612 and although I don't do a great deal with the stats, they do appeal to the geek in me!
Cheers.
That may solve your IPTV problem.
The TP Link also gives connection information and errors.
Just a brief update on this - I finally found where I'd hidden the HH5, plugged it in and it now works fine - so not the BT TV box!
When I get the chance I'll retry the TP-Link again and see if I can discover the correct settings for my setup.
Thanks again for all your help.
