Do you mean
0
Accepted Solution
Pixelation
Hi there,
I've had a brand new UHD you view box for the last 2 months.
It's started to pixelate on a few select channels but mainly standard definition itv even thro I've got 100% strength and quality??? (I can see the Mendip transmitter from my house about 9 miles away)
If I flip on to itv HD no problems what so ever but flip back to Sd and the pixelation start again and it's quite annoying!!
Any ideas?
Dmb
Expert
Re: Pixelation
Sounds like the signal is too strong, try an attenuator to reduce it.
0
Re: Pixelation
Thanks for your fast reply, what size would you recommend? 20db?
Expert
0
Re: Pixelation
I would say 12db,you could buy both as they are fairly cheap. Is your aerial inside or outside?
0
Re: Pixelation
Outside
0
Re: Pixelation
Thanks for your help I've ordered a 0 - 20db variable
Let you know how I get on
0
Re: Pixelation
I'm taking the signal strength down to about 91% (but keeping the quality at 100%)and it seems to have fixed it, thanks jam2000
