Do you mean
Expert
0
Problems with new youview box
OK I've had my youview box for a grand total of 6 hours and I'm onto my 2nd factory reset. Both times the guide button has stopped working, I cant press the I button to get information up and bt vision and youview buttons either do nothing or give a black screen. Is this normal ?
Guru
0
Re: Problems with new youview box
Short answer is no. Hopefully an overnight rest will bring this to life.
BTLife | 1967 Plus Radio | 1000 Classical Hits
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Helpful Post?
If a post has been helpful, say thanks by clicking the ratings star.
