Do you mean
Accepted Solution
Re: BT TV error message BTP_20000
@DavidM I've just joined BT as a customer and have hit the same problem with my BT TV. I receive all the Freeview channels fine and the iPlayer app is working, but I don't have access to the BT sports package I subscribe to.
Could you please advise how to fix the problem as in the message chain there is no action.
Many thanks,
Gareth
Moderator
@Gareth-Thomas Hi Gareth, I'm sorry about the problem with your BT sport channels. I've started your own thread to avoid confusion with the OP's issue.  If you send over your details using the 'click here to contact the mods' link in my forum profile to send in your details we'll get this looked into further. You can find the link by clicking on my username.
Neil
Community ModeratorNeilO
Show your appreciation!
Kudos”
Make sure you are logged into the forum otherwise you will not see our contact link when a moderator offers help. When sending us your details please don’t send a Private message (PM), we can’t deal with account/service issues via PM so please use the contact link. Thank You
[ Edited ]
Hi @NeilO
Can you give me a status report on my fault please. I've yet to be contacted and would like to know when the issue will be resolved.
My reference number is 170516-*****
Many thanks,
Gareth
Under ideal conditions, the moderators can normally deal within 48 hours, but they are running a bit behind at the moment as they are only a small team based in the UK. They will however take full ownership until any issues are resolved. T
Forumhelp is back online. Lots of helpful information on BT products.
Some links may be out-of-date, but I will update them when I get time.
My BT TV now seems to be working fine.
Many thanks for sorting.
Gareth
Moderator
Hi @Gareth-Thomas Thanks for posting back to let us know that the issue is already resolved. Sorry we didn't get to you and I will close the case you sent in as it's fixed.
Cheers
John
Community ModeratorJohnC
Kudos”
