Do you mean
Newbie
Re: Series Linking
if i record a program on series link when that program return fro another season will it record automatically
Distinguished Guru
Re: Series Linking
It is unlikely as Youview will not retain series links if no new shows appear in the schedule for a period.  I cannot recall precisely how long a period it is .. think it is of the order of 10 weeks. Also it is down to the broadcaster to determine what constitutes a series and that varies significantly from broadcaster to broadcaster and may not correspond to what you yourself would consider a series to be.
