Do you mean
Accepted Solution
Record function not working, no errors
Hi,
Our Youview+ box (Humax DTRT2100) stopped recording TV programmes about a week ago. We don't get error messages, but nothing happens on the box when we press record, or try to schedule a recording.
Previous programmes we'd set to record were still on the "scheduled" screen, but haven't actually recorded anything.
Similar threads state that a factory reset is the way to cure it, but I only really want to use that as a last resort so we don't lose the recorded programmes (not a tragedy I know, but a bit of a pain Smiley Happy )
It's using the new interface. Manufacturer software 27.50.0. It has previously worked after it upgraded to the new interface. 65% free space.
Things I've tried, which haven't made a difference:
  • Waiting a day or two to see if it fixed itself!
  • Powering it off completely
  • Resetting the remote control
  • Using the BT mobile app to try to set it to record
  • Pressing the record button on the box itself
  • Re-scanning the TV channels
  • Checking TV signal quality and broadband connection
  • Cleared out the shows in the scheduled recordings list
  • Deleting a couple of programmes
Things which DO work:
  • Pause and rewind
  • The remote flashes blue when the record button is pressed, so it's not a faulty button
  • Apps like iPlayer and All4
Is there a known fix, or is it one of those wipe-and-start-again situations?
Cheers
Mike
Distinguished Guru
Re: Record function not working, no errors
It would be worth trying a maintenance mode reset optiion 4 (keeping recordings)  options before  resorting to a full factory reset.
https://support.youview.com/youview-box/box-and-remote/using-maintenance-mode?q=mainte
BT TV Expert
Hi MikeFishcake,
Please see Box Won't Record Since Software Update
I'd be happy to extend the same offer to yourself.
Steve
BT TV ExpertSteveM
Show your appreciation!
Kudos”
I am a BT Employee and an expert on TV queries. I am here volunteering my own time to give advice, and help where I can with BTTV queries. Go here for more info.
Zulu17 - thanks for the advice, I gave that a try but unfortunately it didn't work.
Steve_M - that sounds like it might be something worth doing; how do I go about getting that sorted?
Mike
BT TV Expert
Drop me a PM with your account number and I'll post one Smiley Happy
BT TV ExpertSteveM
Kudos”
Hi Steve - PM sent, cheers!
Hi Mike, did you get a new box and a positive result? I have the same situation.
Hi Paddy - Yes, the replacement box solved my problem - I can now record again!
A massive thanks to Steve for getting this sorted.
Steve - I've sent you a PM.
Mike
Moderator
Hi @MikeFishcake,
Thank you for posting back. I'm happy to hear that the replacement box has resolved the issue.
Cheers
PaddyB
Community ModeratorPaddyB
Kudos”
Make sure you are logged into the forum otherwise you will not see our contact link when a moderator offers help. When sending us your details please don’t send a Private message (PM), we can’t deal with account/service issues via PM so please use the contact link. Thank You
Hi Steve, I am getting the same issue, could you help me also?
Carl
