Do you mean
Newbie
TP Link Archer VR400
Hi,
since subscribing to Infinity a couple of months ago my laptop suffered terribly with the BT HH. So I replaced it with a TP Link Archer VR400 (AC1200) seen http://uk.tp-link.com/products/details/cat-15_Archer-VR400.html
Now I'm contemplating ordering BT TV but I can't find any info on this exact model and if it will work. I read the sticky posts that say you have to be able to set VLAN ID to 0 or none? My router has a box for setting that value but it has (1-4094) next to it.
Does that mean it will not run BT TV?
Re: TP Link Archer VR400
I've been using the VR400 since last year. I don't subscribe to BT TV but use all the players. It's the T1000 YouView box from BT. The VR400 works straight out the box, no need to set VLAN.
