Do you mean
Accepted Solution
Upgrade Box to You View
I have BT Vision box (old) one, can you upgrade to You View Box & will I still be able to use my ESPN card in it
Guru
Re: Upgrade Box to You View
Hi, yes you can upgrade if you are out of contract http://bt.custhelp.com/app/answers/detail/a_id/40469/kw/Upgrade%20to%20Youview%20box/c/348,1155,2799
you wil not however be able to use your subscription card.
Hi thats for that but with having a subscription card I think I'll just leave it.
I WOULD IV JUST GOT MINE AND ITS **bleep**  STOPPED WORKING ALREADY !!!!!
OMG that's not good
wished id stopped with ntl  it was faster and never went down  cheapest is not alway the best  are you BT !!!!!!!!
I've been with BT for a year now & it's been really good but I don't have the new You View Box & not going to upgrade to it either as you can't use the ESPN card. I was with Virgin but not impressed with them at all.
never had a prob with them i so wish i never changed
I don't work for BT I'm just a customer & so far BT has been the best I've had
