Do you mean
Youview box won't connect
For a few weeksy youview box won't connect to my router. Sometimes rebooting works but not today!! All other devices are working fine in the internet so I have no idea what is wrong....
Re: Youview box won't connect
Welcome to this user forum.
How is the YouView box connected to the BT Home hub?
Have you tried a factory reset of the BT Home Hub?
Forumhelp (Private website) Lots of additional information for BT Residential Broadband connections only.
Hi Keith It's connected by Ethernet cable. I haven't tried a factory reset, will I lose anything?
Factory reset only the BT Home Hub, not the YouView box.
You will only lose any personal settings on the home hub, it will not affect the YouView box.
Factory reset your home hub
Then that leans to a problem with the box, not the Hub, if its a Hub. Are you using a BT Homehub or third party router?
Im using a homehub. Tried a gactoeyvreset on the hub but no change.
Sorry that should read factory reset!
[ Edited ]
If your using a BT T2100 press & hold the power button on the box until it turns off and it will soft reset. It will take about 2 minutes for the box to reboot. Then reboot the hub again.
I've done that several times over the last few days and still nothing....
Then you may need a new box. But first get a mod involved. They can manually look at and analyse your setup.
