paulgoode
0
Channel Unavailable
Hi,
Is anyone else not receiving any internet based services? BT Sports, ESPN all have error code IPC6011, BT Vision on demand loads but every show will not load. iPlayer loads, but the programmes don't play! Anyone know if there are known issues or where I can find out as BT don't have anything about what these codes mean anywhere on there site!
Cheers
Expert
notoriousdbp
0
Re: Channel Unavailable
Are you using a home hub or an alternative router?
---Remember to mark as 'solved' and give stars when you like a post---
paulgoode
0
Plugged directly into the home hub!
Guru
stuartrogerson
0
Which Hub?
________________________________________
If you like a post, or want to say thanks for a helpful answer, click the white star.
1967 Plus Radio
BT Life
Kafka's World
1000 Classical Hits
paulgoode
0
paulgoode
0
Ok, so that wasn't what i wanted to say! It's an outreach modem attached to a bt home hub. Does that help?
Guru
stuartrogerson
0
Which home hub?
1967 Plus Radio
BT Life
Kafka's World
1000 Classical Hits
zarf2007
0
paulgoode wrote:
Hi,
Cheers
I had this problem occur recently and it was only fixed when i power cycled the white BT openreach modem, my router and then the youview box in that order...
paulgoode
0
Ok, will try that straight after work. Fingers crossed!!!!
Newbie
wistleithelps
0
its funny how the codes show on your tv but yet bt dont have the answer online ive got same problem plus another code i wish i hadnt got it its rubbish
