speedtrip
Expert
Message 11 of 63
Re: 22.17.0 software update
Still waiting .... anybody know the algorithm used to roll out the update ? Model # order, Geographical .... or what ?
ney
Expert
Message 12 of 63
I'm also still waiting to get the new software update.
Darren
Old_Welsh_dragon
Message 13 of 63
Still waiting here too... Smiley Sad
TNT555
Message 14 of 63
restart your boxes if you haven't got it.
My UHD box after it's been up a week or 2 stops checking for software updates correctly. It can do it properly and get it just fine after a reboot. just hold the power button down on top of the box for a 10 seconds, then when it reboots it should inform you of the update almost as soon as it's finished booting.
softsorter
Message 15 of 63
Is the update going to fix the ongoing cutting the end off series recordings, that would be worth a update
ney
Expert
Message 16 of 63
I agree about cutting end off some series recording but when I asked about this a few months back I was told it how some of the channel send out a signal or something.
Also about resetting the box I have tried this and no.luck. Anyway I don't have the Ulrta HD box just the BT Youview + G4 box.
Darren
softsorter
Message 17 of 63
Thanks for the reply Darren, but its been going on so long now someone must know how to fix it, charging for a service that does not work properly is not good.
Old_Welsh_dragon
Message 18 of 63
 G4 box Still not had the update.. Tried manual update, just says software is up to date...
speedtrip
Expert
Message 19 of 63
same here: nobody on this site or the YouView Forum seems to know why this update is so protracted .....
Old_Welsh_dragon
Message 20 of 63
Maybe there is a problem with the sofrware they are not telling us about..
Mods can you help..
