scointer
Recognised Expert
Message 1 of 63
22.17.0 software update
People are saying BT boxes are now updating to software 22.17.0. Is it possible to get an official announcement about this (what about the UHD boxes 🙂 ).
http://support.youview.com/articles/Self_Service_FAQ/software-versions-1373538549511
62 REPLIES 62
Moderator
Moderator
Message 2 of 63
Re: 22.17.0 software update
Hi Scointer,
We have started a phased software roll out for those with T2100, T1000 and T2200 Humax YouView boxes.
Manufacturer software: 22.17.0
Component software: 2.10.28
Platform configuration: 1467
What’s New?
A new option called Standby Mode is now available on your YouView box which replaces the old Eco-Mode setting found on boxes with the previous software.  The new option can be found by pressing the YouView Button> Settings> Device Management> Standby Mode.
When in the Standby Mode option there are three settings available:
  • Smart Standby
  • Energy Saver
  • Always Ready
We recommend Smart Standby mode as this improves start up times and overall responsiveness of your box.
Other Improvements
  • The YouView Help App can now be opened by
o    Pressing the Help Button on the remote control
o    A new Help option in the YouView menu
o    Pressing Help when an error message appears on screen.
o    A fix to prevent the YVM302 appearing for issues not related to signal quality.
Cheers,
Robbie
Community ModeratorRobbieMac
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
scointer
Recognised Expert
Message 3 of 63
Thanks RobbieMac, any idea when the UHD boxes will receive this update as I believe it also contains a fix for the glitchy sound...
Moderator
Moderator
Message 4 of 63
Hi @scointer
Thanks for posting back.
We just rolled out a new version of software to T4000 boxes before Christmas to enable Netflix in UHD, so we won't be rolling out any more updates for a while to that box.
All the best,
Robbie
Kudos”
scointer
Recognised Expert
Message 5 of 63
That's really annoying because it was confirmed that a fix for the glitchy sound was found back in September and would be rolled out in version 22+ software (also confirmed it affected UHD boxes).
The version of software rolled out to the UHD box a few weeks ago was still only V21 software and so the people with the premium box are now going to have to put up with the glitchy sound problem that has been fixed but not released on these boxes for who knows how much longer...this seems incredibly backwards to me...
https://community.bt.com/t5/YouView-Boxes/Sound-Dropouts-on-Internet-TV/m-p/1513900#M21684
message 24 :-
‎03-09-2015 12h26
Many thanks to everybody who provided feedback to help us identify and resolve this issue. We do read the forums regularly and it's useful when people provide detailed reports to help us.
The audio dropout and stuttering problem can occur very occasionally on all of the BT YouView boxes including the new Ultra HD box. It typically occurs during ad breaks, transitions and end credits when the video is static or has very few changes. This is a relatively rare problem though and I suspect most users won't even be aware of it.
Recordings are unaffected and should never exhibit any audio dropouts or stuttering.
I'm pleased to report that we have investigated thoroughly and we have a fix in H22.6.0. Unfortunately I cannot confirm when this will be - it may take a while as it is being scheduled with some other changes and the update needs extensive testing before being deployed.
In the meantime, if it affects your viewing there is a very simple solution - just press PAUSE and then PLAY (or REWIND and PLAY if you missed some dialogue). That will resolve the problem completely until you change channel.
Also
Message 42 :-
 21-12-2015 11h34
Hi Everyone,
I don't have an exact date of when the new build will be released Smiley Sad
I do know that this is currently being tested and once that is complete we will roll it out.  As soon as I know more I will be sure to post an announcement on the community Smiley Happy
Cheers
Sean
KernowChris
Expert
Message 6 of 63
Agree with the annoyance comments above, why does it matter that software is rolled out frequently if the pending release solves known problems?
If a solution to an issue is available it should be pushed out even hours after a previous release, not held for some arbitrary reason.
speedtrip
Expert
Message 7 of 63
Dunno about rolling out frequently - once announced, how long does a specific release take to 'roll out' ? 22.17.0 was announced for BT Humax last week - still no sign of it ......
speedtrip
Expert
Message 8 of 63
anybody else had the upgrade ??
- I've just fired up the G4 for the evenings viewing and its still on 21.50.50 ....
speedtrip
Expert
Message 9 of 63
Finger-Tapping smilie ...... :smileysad:
Razorback
Message 10 of 63
Had the update on one box a few days ago, still waiting for the update on the other box.
