Is there any way to change the default 12 hour clock on the YouView box to 24 hour? I find the 12 hour clock confusing at times when I’m searching.
Solved! Go to Solution.
Sorry @mixstar there is no current personalisation of the time format.
The only appearance options you have currently are High Contrast Colours , Transparent Backgrounds and Channel Logos
