Message 1 of 2
4K Youview+ box wont get signal but TV will
Hi,
My box refuses to get a signal with the aerial plugged in, i have to take the end of the coax plug off and rest the copper coax in the aerial socket just to get a signal. The TV works fine when the aerial is plugged in, i have also tried another BT youview box but it's the same issue.
The aerial is pointing to the Winter Hill transmitter but i have the Wrexham-Rhos relay transmitter a stones throw away, could the relay be causing an issue due to the proximity of it to my aerial?
Has anyone else experienced this problem? I just cant get a logical answer/explanation for the problem. Even the aerial installer was baffled by it.
1 REPLY 1
Message 2 of 2
Re: 4K Youview+ box wont get signal but TV will
Could be too much signal causing an overload. Try an attenuator.
See Picture breakup or missing FreeView channels
